Centerforce I, II or DF?
Discussion in 'The Garage' started by mtrdrms, May 19, 2006.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    Well I have to replace my clutch and I think I am gonna go with a centerforce unit. So I go to order it and it turns out that its not quite that simple. I dont know which type to get or the size.
    So I looked up on Summitracing.com and found my specific application and it was a 12 inch. So then I asked a friend what one to get and he said an 11 inch Dual friction. What size is the input shaft? It is a 10 spline right? It is a 465 out of an 84 K10. What gives here and which one would you put in your truck?
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Back when i had a standard i went with the stage 2.
    Reason--
    stage one is basically stock with a little more clamp
    stage 2 is upgraded material, with even more clamp
    DF is a lot more clamp
    from what i understood the DF is either on/off. ther was no in between, which made sence because it geared more toward the racer. i didnt go with the DF because of that. i didn't want to spenda lot of money and get a "stock like" clutch so i went with the 2.
    it was an awesome clutch. crawlin i would be half in/out most of the time and there would be no smell or slip, i could dump the clutch at 4k and roast 38's--again no smell or slip. be sure to get the upgraded throw out bearing. and yes its a 10 spline input.
    FWIW my 305 recommended an 11"er and when i swapped to the 350 it recommended a 12. I was already broke and just swaped over the 11 and it held up awesome.
  3. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    I have a Centerforce 2 in my Blazer and haven't had any problems yet but In my RX-7 racecar it had problems. Not only did it only last only about 8000 miles but when it came out, it came out in pieces! Maybe it was a bad clutch. On a side note: How well is the Blazer holding up with popping the clutch at four grand? I have 37's in a Detroit locked 12 bolt and I admit I am scared that I am going to break something with that kind of abuse. Though I want to do it. Real bad.
  4. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I have since got auto (only because of the doubler) and everything held up fine (welded 14ff) little weight in the back.
  5. uberbeans
    May 14, 2004
    564
    But it was holding up to that abuse with the manual? What gears?
  6. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    293
    Truckee, CA
    with a 12 bolt i wouldnt' do it, he had a 14 bolt.....
  7. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    I am running a dualfriction unit in a k-3500, 454, sm465, 4.10 . Its a everyday driver, and my tow rig. I pull a 28' fith wheel that weighs about 8500. Mine works great, you can feather it if need be.My only complaint is, that the hydro clutch has zero feel in the pedal, and you can't set the engagement heigth .
  8. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    Luk pro gold series. If that is not a option i would settle with the dualfriction.
  9. Big Truck
    Big Truck 1/2 ton status
    Feb 19, 2005
    129
    hermiston, OR
    I got a dual friction with a hydro clutch, it works pretty smooth no problems or issues.
  10. greg mgm
    greg mgm 1/2 ton status
    Apr 6, 2005
    152
    Pine Cove (near Idyllwild) CA
    My 78 has the dual friction. Stock pedal feel, no problems at all. Definitely will buy another down the road.
