centering rear with new perches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Sep 9, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, I got my perches between the springs and the axle tube and I took some previous measurements to help get the pumpkin centered correctly before I start to welding the bad boys on. But for some reason it just doesn't look dead on centered. I dont have the driveshaft yet. Im gonna bolt the d-shaft up first for more comparison before I start welding but was wondering if you guys had any other ideas or trick tips to making sure I have the right location for these perches as far as left to right.
    I have another 14 bolt in the garage and the perches are
    4-7/16 from the tub side of the backing plate mount. So I got these perches lined up with the same measurements.
    Any more ideas? The centering part has been the only real pain in the arse here. The angling part is a breeze.
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  2. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Also, is the yoke supposed to be dead on center between the frame rails or is it a little offset? I was trying to get a measurement from the leaf springs but they are a little too in consistant as they can move in and out.
    But basically I didn't take enough numbers before I too kthe old perches off. Bad brandon bad brandon!!!! Can some one spank me? Preferably a sexy hot lady?[​IMG]
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Somebody?
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I would just go with the measurements from the other axle if it is a 3/4 ton. Those measurements should be what you need for your truck.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    The only concern I have with that is that the perches that rene made for me are 1/16 of a inch wider than the ones on the other axle. And yes it is a 3/4 axle setup.
  6. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Well 1/16" shouldn't make a world of difference. Just amke sure you have a reliable surface to measure from on each side of the axle. Look for a nice flat spot on the backing plate and use that, then make sure its exactly the same on each side and your width is correct and you should be good.
    I don't think the pinion is dead center...but I could and probably am wrong on that. In any case the pinion would be very hard to measure center on.
    Rene
  7. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    the reason it looks off center is cuz the pumpkin is off-center look at the drive shaft to be straight centered also if you got measurements from another diff. go with it
    <font color=purple>I put the Panic in Hispanic</font color=purple>[​IMG]
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  8. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I was wanting to measure the width but its a pain in the arse to get that with the tape having to wrap around that big ass pumpkin.[​IMG]
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you have two 4" rear blocks laying around, set them on the perches and then measure across to the holes. Those 4" blocks are tall enough you can measure OVER the pumpkin without 'bending' the tape measure.
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  10. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well I sold my 4" blocks to dawson444. But here are some pics. But they are probably not true enough for good advise.
    <a target="_blank" href=http://www.nashvillek5.freeservers.com/sunday.htm>www.nashvillek5.freeservers.com/sunday.htm</a>
  11. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Just had mine welded on. Center to center for a K5 at least 89 is 42.5. If I remeber correctly the perches had to be moved outward 1.25 per side from the one ton axles config. Mine bolted up no problems.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  12. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Those look swanky!!! Now all you gotta do is weld it up! [​IMG]
    Rene
  13. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I aint sweetin the welding stuff long as I have them out in the floor like all my practice projects. The welding stuff on the truck overhead, sideways and all that other [censored] to deal with really does suck! I just experienced this first hand this weekend
  14. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Welding in position is much harder...
    Welding where you can't see what you're doing is even worse. I've had repairs where I've had to weld by braille...[​IMG]
    Rene
  15. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    LOL!!! Braile!!!! Just like the braile on drive through ATM machines!!! Whats up with that?[​IMG]
  16. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Well I know here many drivers should be using braille...lord knows they drive like they're blind.[​IMG][​IMG]
    Rene
