Centering steering wheel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KENT, Jul 11, 2001.
  1. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    I just completed my lift. How do I return the steering wheel to center. It is now about 1/3 turn to the right when the truck is going straight.
    Kent
    1989 K5 33X12.5 with 2.5" lift 12 bolt with aubur posi running 3.73 gears.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Need to take it in and get it aligned - Once you get the drag link lengthened a few turns, you should be back in the center.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A> Updated finally[​IMG]
  3. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    Is this something I can do myself. I hate to pay for something simple.
    Kent
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    No need to take it in for alignment, but you can if you wish. Installing a lift does not affect alignment (doesn't mess with the tie rods), it only adjust where "center" is. Here is what I did...
    Put you front axle on jack stands.
    Unlock your steering column, center the wheel, and lock it back again.
    On your drag link, loosen the two bolts strapping the center of the link tight. You don't have to remove them, just loosen them.
    Now, wedge a solid screw driver or a small crowbar into the slot on the center part of the link that you just loosed and rotate it. As it rotates, it will expand or contract the link, depending on which way you turn it.
    Turn it a few turns and then look at the wheels and see if they are straight yet. If so, voila. if not, crank it a few more turns and check it out again.
    This process isn't perfect, but it works pretty good. And it saves money of an alignment. And, if you decide not to do this and take it in for an alignment, be sure to tell them you want the wheel straightened. An alignment simply lines up the wheels, it doesn't take into consideration the position of the steering wheel. It simply adjust the tires themselves in relation to each other.
    85 GMC Jimmy, 305 w/TH700-NP208, 4" lift, 35X12.5 BFG MTs, 15x10 Hellcats, Smittybuilt tube nerf bars and bumbers
  5. gpd4
    gpd4 Registered Member
    Jun 25, 2001
    55
    St. Louis, MO
    Or just wait - you'll get used to the offset wheel. Mine wouldn't fit in the alignment rack, so we did it with a tape measure. About 3/8" toe-in. There's only the one adjustable tie rod end ( on mine ) to do the toe in. The other clamp ( above the front tire ) will center the wheel.
    '85 Blazer... 9" lift... 35-12.50 BFG AT's...LOTS of rust
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I prefer to take it in and get it aligned whenever I mess with the suspension/steering. You could do like 85 GMC said and do it yourself, but for the cost involved (usually $49), if you haven't had it aligned in a while, I'd take it in and get it done.
  7. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    I was planning on having it aligned when I get tires in a couple of months. Right now it's messing with my blinkers being off center.
    Kent
  8. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Someone has pulled the wool over you eyes !
    An alinment and streeing wheel are not related ?
    NOT
  9. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I guess my key here is that unless you did something with the tie rod during your lift installation (which is highly unlikely), you haven't affected your alignment. Alignment is the distance between the two front tires. What you did was simply change how the steering box links to the steering arm. So all that needs to be done is the adjustment of the drag link. This will in no way, sort, or fashion impact your alignment. Only tie rod or camber adjustment is going to do that.
  10. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    Alignment has to do with the positioning of the tires in relation to each other (toe in and toe out) and with their tilt (camber). Steering wheel being off-center has to do with the center point of the steering box and the center point of the tires. If you let go of your steering wheel (which is off center) and the vehicle continues to go straight (no pulling), then you have a centering problem, but not an alignment problem.
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The only thing that they "adjust" (besides your bank account) for the $49 is your toe-in and center the wheel. [​IMG] Unless you've bent parts the toe-in should be fine anyway. They can't adjust the caster or camber without getting into some serious work that drives the price up considerably. The drag link adjustment doesn't affect the actual alignment of the wheels, just the steering wheel itself. It certainly isn't worth $50 to me to have someone else turn the adjuster sleeve on the drag link. [​IMG]
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
  12. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Hey Kent,
    When I did the one ton conversion I had that problem, the way to correct it is stated above, by adjusting the drag link to center the wheel.
    The toe-in recommended was 1/8" toe in, not sure if that or 3/8" would make a heck of a lot of difference but the place I took it does nothing but LARGE 4 wheel trucks (the one's that don't fit in a standard alignment rack) and they said 1/8". Just their $.02...........
    I hear you on the blinkers...........aggravating!
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.alloffroad.com>http://www.blazzinor.alloffroad.com</A>
  13. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    The last time I took one in for an alignment it was on an F-150, and I got out of there for 49 bucks, + $13.50 a piece for new camber bushings. I guess it depends on where you go - I take mine to a local tire shop, or the dealer, and always get the full package.
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A> Updated finally[​IMG]<P ID="edit"><FONT SIZE=-1>Edited by Pugsley on 07/11/01 03:31 PM (server time).</FONT></P>
  14. dyeager535
    26,982
    191
    Wow, they actually adjusted your wheel? They took mine, put it on the rack, said I did a good job for eyeballing it (too the person that took it in for me while I worked) and took my money, and shut the door. I had to do the drag link myself.
    As was said, if vehicle tracks straight with hands off the wheel, adjust the drag link. I had to adjust mine a few times to get it right, but eventually I realized, if you turn the draglink clockwise, the wheel turns clockwise. Pretty durn simple lol.
    Hard part is getting it to move. Take the tire off. Undo the two clamps until the bolts almost fall out. Take a big screwdriver, or some strong tapered pointy thing (like end of a crowbar) and spread the seam on the drag link a bit, to break the corrosion. Lube somehow (I used grease, so if I ever needed to again, I wouldn't have to go through the trouble of spreading it..WD-40 works though) the threads of the drag link ends.
    Now you can use a pipe wrench, or if loose enough, even vise grips, to turn it to correct. Once you get it freed up, and adjust it some, tighten back down (enough so that the threads can't "slip" when you test drive) the nuts/bolts, and test drive it. Doesn't take but a few seconds to realize if you are making progress or not. With the sleeve lubed up, you can adjust it with the tire on, just crawl under the truck and loosen the bolts, twist the link a little bit, retighten, and try again.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  15. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Those Ford Twin Traction Beam front ends have adjustments for the caster and camber. Dana 44's, 60's, 10-bolts, and other solid-axle front ends don't have that "feature" so there's not much to adjust.
  16. Executioner
    Feb 22, 2000
    1,530
    Yes they should center the wheel for a professinal job.
  17. nd_4_mud
    nd_4_mud Registered Member
    Mar 16, 2001
    40
    new jersey
    I thnk that once the toe in is right (3/8 toe in) and you center the tire, the pitman arm is suppose to be 90 degrees from the steering box. It would make a perfect T. If i am mistaken please let me know.
    Knowledge is the key to the universe, and I hold that key when i am sleeping.[​IMG]
  18. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I worked at the Sears auto center right after high school and when we did alignments we centered the wheel with a brace, then do the alignment. If anything is off, it is fixed.
