CFM of stock fan?
Discussion in 'The Garage' started by jjlaughner, Jun 26, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Just curious what the stock fan CFM is?
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I'm curious to find out the number myself.
    I had a 2950CFM Permacool fan and my stock setup pulls way more CFM's than the permacool did.
  3. dyeager535
    26,979
    I don't think I've ever seen that data, and I've been looking. /forums/images/graemlins/frown.gif
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I picked up a 1900 CFM electric fan, just curious what the stocker pulled? /forums/images/graemlins/1zhelp.gif
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Thats going to vary with the speed of the fan and weather the clutch is fully engaged. I know when it is engaged, it pulls pretty well
  6. dyeager535
    26,979
    Do searches on electric fans. I think you'll see minimum anyone has had any real success is 2200CFM or so.
    Most run dual fans that pull somewhere around 5000CFM total if running a big inch motor or doing a lot of crawling in warm weather.
  7. Grim-Reaper
    7,385
    Atlanta
    with clutch locked around 1000RPM of engine speed stock fan with the shrode is probably moving 4,000+ They pretty well stall out at that. The resitance of the fan moving the air is more then the fluid clutch can handle so at 3,000 rpm it's still moving about the same air as 1000rpm.
    I know when mine is full locked with the hood up if I had a lonjg haired hippy stand next to the fender it would be blowing their hair pretty good. NEVER seen a 12v electric move near that much air.
  8. Waxer
    1,857
    Long Beach, CA.
    I've had similar experiences.
    With the 2950CFM permacool setup, I would have to put my hand past the grill and onto the radiator to feel the suction.
    With the stock setup back on, if I stand in front of the truck, my shirt gets sucked into the grill. Which is about 6" away from the radiator. Love that stock setup.
  9. 88Silverado
    Mar 13, 2003
    2,664
    The commercial electric fans (ie Winstar, Mark-VIII) pull close to 5000CFM. On my 355 in my Elky the stock clutch fan setup could not keep the car cool when idiling and the air running during summer. I switched over to a heavier clutch and fan off a truck and that seemed to help but I could feel a hugh drag on the engine when accelerating until the clutch disengaged. I also feel the same thing on my Blazer. I have had no problem with the Winstar setup. Pulls lots of air. Seriously thinking about doing the same conversion on my Blazer cuz the load and fan noise bugs me.
