CFM Recommendation
Discussion in 'The Garage' started by 79Stomper, Jan 14, 2005.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Just want a few bits to back what I am thinking.
    Engine GM Goodwrench 350, 4 bolt main. Stock. 74cc head running roughly 8.5:1 compression ratio.
    Will be doing a cam change when engine comes out and freshening it up.
    Looking at the Edelbrock Pro Flo EFI (750 CFM) and the Edelbrock Performer Pro Flo EFI (1000 cfm).
    Would the 1000 cfm be overkill to the engine?
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    1000 cfm is overkill for my 454 :blush:
    I'm thinking 650-750cfm will be just fine for you:waytogo:
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    fuel injection uses more CFM than carburated. So your 454 1000 would not be overkill. 750 sounds about right to me. Someone correct me if I'm off here but I think TPI stock throttle body is about 650CFM maybe 700.
  4. dyeager535
    26,980
    Actually believe its around 500. But thats choking a healthy 350 (along with other things like the long runners) so I'd suspect much more than that for a healthy 454.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you sure? I know TBI is like 450-500 at best.
    Just found it, factory TPI is 625 CFM. The bigger throttle bodies for TPI flow 1000CFM(accel).
  6. dyeager535
    26,980
    Yep, finding the same info. Apparently the stock throttle body isn't the hinderance the runners and intake are.
  7. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    All right going to go with 750. I was thinking the 1000 would be over kill. So going to go with the 750. Thanks.
  8. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    1000 cfm would sound really cool when talking around the campfire though :cool1:
