chain link fence pipe
Discussion in 'The Garage' started by tecton, Apr 22, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    is that stuff good for anything other than the fence?
    i found a whole crap load of it out in a field...looks REALLY thick
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I wouldn't trust it for anything but fence post, especially if it is that galvanized stuff.
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I think that stuff is glavanized, and I don't imagine welding on it would be any fun
    For bumpers and stuff like that it cant be bad, I wouldnt trust it for cage, just , you know, because it's fence pole
    Anyway, I'll use ANY steel to make non cage items on my truck, I know I used a bunch of washers to weld up a table at work
  4. tecton
    Dec 1, 2002
    1,553
    WV
    is galvanized hard to weld?
    i was imagining bumpers with it
  5. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    I work with galvanized sheet metal every day and the gasses from welding or burning it can KILL you. I know first hand /forums/images/graemlins/frown.gif
  6. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    You have to clean off all the galvaniziing in the area you are going to weld with a grinder
    Plus weld outside or in a well ventilated area with a proper respirator as it will make you very sick (poisoning you)
    Also wear leathers as galv. will pop and sputter the puddle giving you some nasty burns
    Go to a welding supplier and they can tell you the proper rod ,wire and gas combo for your equipment
    This has been my exp. with galv. hope it helps.
    /forums/images/graemlins/thumb.gif
    P.S. you can paint over welds with cold galvanizing compound (spray can) to protect the welds
  7. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    its pipe not tube.... with a seam that would split under compression of a roll... its also made of the worse scrap steel...
    the galvie coating can be welded through using certain types of rods or flux core... but the welding process as previously noted is very toxic... grinding it off would be a pita...
    SKIP it...
    cam
  8. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    SKIP it...
    cam
    I second that
  9. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Don't weld it. Its bad. Or get the right stuff needed for it. I have a respirator for welding galvanized sheet metal /forums/images/graemlins/thumb.gif
  10. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Used it once on a 'Zuki/buggy to make a straight pipe exhaust. Sounded like a bad ass weed eater on crack. /forums/images/graemlins/thumb.gif
  11. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    If you found it in a field, its there for a reason.
    At the risk of sounding like Tim, Cow$hit can also be found in a field. Would you use that on your /forums/images/graemlins/k5.gif ?
  12. tecton
    Dec 1, 2002
    1,553
    WV
    its big and heavy and feels expensive, lol
  13. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    Scrap is going for a pretty penny these days
  14. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    You going to build a cage for your future children? /forums/images/graemlins/smirk.gif
  15. diesel4me
    Jul 24, 2003
    17,540
    928
    Massachussetts
    i have used chainlink fence and emt conduit tubing to build long lasting exhaust pipes and even a stand to hold the fiberglass roof on my old 72 K5 I had--it looked like a swingset,only the top of it was the same heigt as the bed of the blazer so I could slide the roof right onto it.Dont take the warnings about the "zinc chills" too lightly--I did and beleive me,even a mild dose of those fumes will make you wish you used black iron pipe instead.The good thing is it doesent rust for a long long time.I dont think I'd use it for anything structural,though a friend made a carport out of it and its still there 10 years later.If you must use it,grind off the zinc and weld it outdoors--even with a fan running outside chances are you'll get a whiff of that nasty white smoke--it will give you stomach cramps and diarrea(ask me how I know /forums/images/graemlins/blush.gif).I use a lot of galvanized sheet steel to patch my rotted trucks,but end up paying the price after welding it in.Then your truck rusts around the edges of the patch and your back to square one!.They out to galvanize the whole cab /forums/images/graemlins/thinking.gif,but then we'd never have to buy another one,would we?. /forums/images/graemlins/tongue.gif
  16. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    I SECOND THAT /forums/images/graemlins/deal.gif
