chaining down box
Discussion in 'Audio' started by 85GMCJimmy, Oct 23, 2000.
  1. 85GMCJimmy
    85GMCJimmy Registered Member
    Feb 21, 2000
    83
    South Carolina
    I was thinking about running a you bolt through my box so i could run a heavy cable through it and go around and through the spare tire mount and locking it with a pad lock. By running a bolt throught the box would it eventually vibrate the bolts lose? or what, To give you and idea of what i have i have 2 MTX 10s and a MTX 250x amp. The amp will be bridge so it will have 100 watts to it
  2. Chewy
    Chewy 1/2 ton status
    Sep 4, 2000
    197
    Parker, Colorado, USA
    If you are going to drill holes into the box just make sure you seal them after you install the U-bolt. The cheapest tube of caulk should do the trick. Just make sure it has silicon in it. I don't think it would wiggle loose as long as you don't drill the holes to big. Good luck.[​IMG]
    [​IMG] '87 Beast
    Colorado, USA
  3. freeforever
    freeforever 1/2 ton status
    Feb 21, 2001
    305
    Missoula, MT
    Put some liquid nails in the hole your puting the bolt throu and that will insure a good seal and probaly keep it from vibrating.
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I am assuming you are doing that to keep it from being stolen? I got ripped off and most insurance companies will not cover that loss unless it's mounted to the Blazer itself. It has to be considered attached to it by means of screws/bolts. I found that out the hard way. I lost it all and they covered nothing due to fine print. I even asked them and was told the wrong thing by this guy. Call them up and get some stuff in print to make sure because you can always buy some cheap hardware and attach it to your floor to be safe. :-)
    "I love the sound rice burners make when ya run over them"
