Change 2wd th400 to 4wd?
Discussion in 'The Garage' started by LucasJ03, Mar 19, 2005.
  1. LucasJ03
    LucasJ03 1/2 ton status
    Sep 18, 2002
    289
    Ft. Fun, Colorado
    Can you swap the tailshaft housing and output shaft on a 2wd th400 to a 4wd housing and output shaft to mate it to a transfercase?
    Lucas
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes you can but you will have to tear down the entire tranny
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    From what i understand if it was a fixed yoke TH400 from a truck or Vette all you need to do is remove the tail housing and you now have a 4x4 TH400. :thumb:
  4. LucasJ03
    Sep 18, 2002
    289
    Ft. Fun, Colorado
    that's what it looked like I could do but I didn't know for sure. I have one from a 69 3/4 truck so I think I'll keep it for a th400-203-205 set up and get rid of my 700r4-klune v-208.
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Yup, thats what I did. Fixed yoke from an 84 3/4 ton. Took off tail housing, attached the t case adapter and slid the 205 on. Fixed yoke TH400's had a longer output shaft.
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    That's fine if you want a TH400/NP205. If you want to run a NP203 with the factory adpater you need a shorter trans mainshaft.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep!
    and i didnt know that for the 205 case
    thats pretty interesting that 2wd and 4x4 output shaft for 400 is same across the board
    thats very interesting!
    hum
    too bad th350 arent like that eh ?
  8. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    most 205s take that shaft but dont forget the short and long input on 205s for 400. i have the long one and the shaft length is different than the short one.
  9. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    stupid question...
    I have a TH400 out of a 74 Monte Carlo that had a 454--could it be used in a 4x4 by removing the tail housing and making a spacer block to take up the extra lentgh of the tailshaft??(I realize the transfer case would have to be moved back some to accomadate the longer overall length,and the driveshafts would need to be altered)--or would a divorced T-case be easier in the long run??:confused: --just wondering if its worth keeping as a spare for my 82 K20--I suppose I could have the tailshaft from my existing tranny installed in it-maybe that would be easier..:confused: I'm hoping I never have any tranny problems(works great at the moment)--but its had a good beating plowing this winter,and will likely get many more to come..:crazy:
  10. LucasJ03
    Sep 18, 2002
    289
    Ft. Fun, Colorado
    What if I want to make it a th400-203-205 set up? would I need the short shaft?
  11. sweetk30
    Nov 1, 2004
    25,539
    538
    for all 203 setups its the 3/4" stick out shaft and or short shaft. the stubby one. then the dubbler kit to mate all other parts.
