change 2wd tranny to 4wd tranny
Discussion in 'The Garage' started by Taz, Apr 23, 2004.
  1. Taz
    Taz Registered Member
    Dec 31, 2000
    77
    SE Wisconsin
    Hi I have a 1969 400 turbo tranny from a two wheel drive truck, I would like to convert it to a 4 wheel drive tranny. How do you do this? thank you for your help /forums/images/graemlins/1zhelp.gif
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You need to unbolt the yoke and tailhousing and get a measurement.
    If the shaft stickout is 2.5", then you can bolt on a NP208 or NP241.
    If the shaft stickout is 4.5", then you can bolt on an NP205.
    Other length/spline shafts can be swapped in, but require a full tear-down to install it.
    Trouble is when you're buying a t-case and adapter, usually the tranny comes as part of the package /forums/images/graemlins/whistling.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    2wd tranny wil not have 4x4 output shaft, you will need to put a 4x4 output in the tranny since it has a 2wd one in it currently
    good luck
