change 6 lug to 8 ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Apr 20, 2001.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    I have a dana 44 6 lug and a 14 bolt ff rear with spring perches allready weldin in and everything know i just wanna know how much does ti cost to change a dana 44 6 lug to an 8?....the reason for doin this is that i just bought 38 inch gumbo mudders and they have have 8 lug 16.5's so gotta get the 8 lug pattern goin in soon......thanks for your time
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    You should ask Waxer about it since he did the write up on the tech page for changing his 6 lug to the 8 pattern. I believe he said when he did it ran him like $575 to do it?
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    "What if the hokey pokey is what it's all about?"
  3. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Damn she's good!! :) Yes it was roughly $575 for the conversion with all NEW parts.
    <A target="_blank" HREF=http://www.coloradok5.com/8lugconversion.shtml>http://www.coloradok5.com/8lugconversion.shtml</A>
  4. wheelin247
    Aug 29, 2000
    178
    hayward,ca
    ok thanks alot for yours help guys and gals.Im only 16 so i need as much help as possible thanks.
  5. extremeblazer
    extremeblazer 1/2 ton status
    Dec 5, 2000
    129
    Albany NY
    If you want to do this cheap, take a trip to your local salvage yard. For 75.00 I purchased all the parts to do both sides. That included new hub housings, spindles, backingplates and rotors. Reuse your old hubs and calipers. The rotors I bought were good but if you need to purchase new they don't run that much. Just check bearing for wear and replace seals. I did it all for about 100.00, 125.00 for my other truck and my partners truck 175.00 with new bearings and rotors.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Hell, you may be able to come across a complete 44 with 8 lugs for cheap, depending on what ratio you are running. I bought mine for $25.. It was an 8 lug with 4.09's.............
    This way all you have to do is change some maintenance items and bolt it up.
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
