change anything else when installing 1" body?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by boots, Nov 17, 2002.
  1. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    change anything else when installing 1\" body?
    what all did you have to change when doing a 1"body lift? as many know I'm changing body mounts and if you all didn't have to change much else I figured I'd go machine some 1"pucks at works if you didn't have do to much else. Brake lines, OEM shifter, fan shroud etc etc. What did it entail? Cold rolled steel pucks OK?
    boots
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Re: change anything else when installing 1\" body?
    All you need is longer bolts and a small extension rod for the PRNDL(shifter). I bought a 3" for my truck for cheap, you might as well go with a 2" kit that comes with everything needed and light weight plastic spacers. /forums/images/graemlins/burb.gif
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I used 1.25" machine blocks. I also added new poly bushings (added about an 1" over the worn out rubber bushings)
    I added in 1.5" U channel between the top and bottom sections of the fan shroud and used bolts to hold it together. I had to adjust the transfercase shift linkage and moved some cooling/trany lines. Other than that nothing big to report other than some nice clearence.
    You can kind of see in the lower left corner of the pic, if you want I can post up a better pic.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Every truck is different,but here's what I had to do.
    Trim the fan shroud
    Cut the tailgate springs
    Adjust the t-case linkage
    Good Luck! /forums/images/graemlins/rotfl.gif
  5. boots
    Nov 3, 2002
    183
    ok it's late, well for me it is. I'm not quite seeign what I think I should be seeing in the bottom left of that pic, if you could post one or a few more or email em to me that would be great. I halfway think I am undermeaning what you stand but not 100% sure.
    Shawn
    boots@commerceconnections.com
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Yeah its not the greatest pic I was trying to find one on my site and that was the closest, I will try to post one tomorrow. Its supposed to be nice and sunny so I am going to wash the /forums/images/graemlins/k5.gif. /forums/images/graemlins/thumb.gif
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Is that better /forums/images/graemlins/grin.gif
  8. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I changed the filler neck for the gas tank when I did my 1in, I had to trim the fan shroud, adjust the tranny linkage thats about it.
    Eric
  9. boots
    Nov 3, 2002
    183
    mucho grassyass, much better, now I see zactly what you were talking about
