change from 2.73- to 3.73 gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MITCH_89', Feb 18, 2003.
  1. MITCH_89'
    MITCH_89' Registered Member
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    Ive had about enough of the factory 2.73 in my 89' blazer with a 700/350/33s. Ive been hunting for replacement axles, and I found a set of 10-bolts from an 86 blazer with 3.73s for 300 bucks. The question: Will I notice enough difference to make the swap? I have to make a decision quick-like. Everything is in good shape on the axles, and tight
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you would notice a huge difference /forums/images/graemlins/shocked.gif
  3. MITCH_89'
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    I wanted to hear that...Were the gov locks popular in 86?
  4. lazerus
    lazerus Registered Member
    May 13, 2002
    51
    north texas
    oh yea, big diff. I did the exact same gear swap /forums/images/graemlins/thumb.gif
  5. dyeager535
    26,980
    Gov-locks are/were popular in all the 10 bolts. If the donor truck has "G80" as one of the RPO (option) codes in the glove box or inner fenderwell, more than likely it's a gov-lock.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    gov lok as most ppl well know is not a good thing to have, if the rear really has gov lok unit in it then id go for an eaton or powertrax unit, or similar /forums/images/graemlins/laugh.gif you will notice big difference going to 3.73, better acceleration by far, but higher cruising rpm's that can be lowered a lil with taller tires, 3.73 is my all time favorite all around use ratio, i love them /forums/images/graemlins/laugh.gif and i miss them, but i recently found a truck im gonna be getting thats 1 ton, so 4.10 probably /forums/images/graemlins/laugh.gif
    have fun ! /forums/images/graemlins/laugh.gif
  7. MITCH_89'
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    Thanks for everyone's input. I feel good about the decision now. Its always good to hear positive things /forums/images/graemlins/cool.gif
  8. MITCH_89'
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    Well, I brought the axles home last night. Turns out, the rear is a 12-bolt. The guy said they came out of an 86 Blazer and they were the original axles, but looking at the spec sheet on Colorados front page, 12-bolts were in 81...no biggie, they both have 3.73, and seem to be ok. Should I do anything to the axles, besides change oil, before I install them. Is it a good idea to go ahead and pull the axles shafts out and do new seals, berrings? I am going to reuse my front calipers and roters, so I will put new berrings in at that time. The front also came with warn lockouts, so goodbye to the autos. Thanks for inputs
  9. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I would go ahead and atleast put new seals in them. If you are going from a 10 bolt to a 12 you will either need to get a conversion ujoint or change the yoke.
