Change Gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Jun 8, 2000.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    So if I change my gearing from 3.07 to 4.10 do I have to change both front and rear?? also how much would this cost to get done?? Does this just make the truck go faster or both more tork and faster? thanks
  2. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Front and rear gears have to match...else you gonna break something next time you go into 4x4...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  3. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    read the newest Petersons 4 wheel and off road, lots of tech info on that. And a physical explination.
    Bryan
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    This month's Car Craft has an article on the effects different gear ratios have on acceleration. They were just using little 28-inch tall slicks, but the idea's the same. They tested a Duster with 3 different gear ratios to see what would happen.
    Expect to spend $600-1,000 to have new gears installed front and rear, depending on what axles you have. You might want to also install lockers, etc. while they're in there. The labor is a big part of the cost.
    http://ThunderTruck.ColoradoK5.com
