change housing or change mounts? 14Bff
Discussion in 'The Garage' started by LKJR, Mar 15, 2003.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I've got a 3/4T 14B FF with the right gears and all, I have a guy here in town that has a 1 Ton and offered to let me swap out the housing, (both are just axles and out of trucks) should I mess with this or just move the mounts on mine? I can do either just a matter of work.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    What are you putting it into? The 3/4-ton will bolt right into a 2nd Gen K5. It's the 1-ton version that needs the spring perches and shock mounts moved around.
    In either case, if the gear ratios are different, then it's WAY easier to move the mounts than to set up the right gears in a different case. /forums/images/graemlins/shocked.gif
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I had the same delima , I ended up swapping out every part out of a K-30 SRW housing and putting it all into the 3/4 C-20 housing. I liked the thought of clean looking tubes and not grinding the perches so I just swapped parts.
    I think it all depends on your resources - if Ya' got access to some fine cutting and welding equipment than keep your housing - if not , than swapping might be the better way to go ???
    Good luck , Tom
