Change stock air intake for wheelin
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Panther, Aug 10, 2001.
  1. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Hey everybody.
    I wanna change my air intake on my 90, 350 TBI for this weekend. It has the the accordion hose to the front clip, then a plastic tube down to the bottom of the radiator.
    Is there anything I can do without cutting? If I unplug the accordion hose from the front, it'll bend over to between the battery and the coolant reservoir above the wheel well (intake). Would it be better secured there than where it is or are my chances of splashing into it greater since the opening is bigger.
    All your opinions are appreciated!!
    <font color=blue>Brilliance is like 4wd, it allows you to get stuck in a more remote location [​IMG]</font color=blue>
  2. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Your air cleaner will need a source of air into it..
    Moving it over the the right side fender.. could cause a problem.
    Perhap's you can route some extra tubing up high on the radiator support into the accordian air tube..
    I know I'm going back to the stock air cleaner.. after bogging my motor down in water crossings..my open element air cleaner got soaked...
    MTPocket's had a awesome snorkel setup on his truck.. Wonder where he got it from.. or if he fabricated it..
    Round Rock, Texas I haven't failed, I've found 10,000 ways that don't work. <a target="_blank" href=http://www.rocko.rockcrawler.com>www.rocko.rockcrawler.com</a>
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
