changed to correct t-stat, now pinging at WOT
Discussion in 'The Garage' started by jshadwick, Mar 9, 2003.
  1. jshadwick
    jshadwick Registered Member
    Jun 24, 2001
    45
    Sacramento, CA
    Hi everyone, thanks for the great advice. Here goes:
    I bought an 87 k5 about 3 months ago, and noticed that it never heated up (the engine or my heater). So after checking the thermostat and recognizing that it was a 160 degree t-stat, I changed it to a 195. Now i got plenty o' heat, but now it pings at/near WOT and make a metalic "flitter" kinda sound (?). Then the check engine light comes on (Goes off after shutting down then restartin').
    *As long as I am fairly gentle with the pedal, no pinging or check engine light.
    I am going to change the t-stat back to the 160 degree one, because I think there may have been a "chip-transplant" that I was not aware of. Does this theory pan out with anyone else??
    Also curious if I have to reset timing or anything...
    thanks,
    James
    87 k5, new (10K) GM goodwrench 350 with stock TBI on an Edelbrock Performer TBI intake.
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Could be a chip change, could be a bad knock sensor.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Yes, I would say that there may be a performance chip in there. Have you checked the timing? I would verify the timing before you swap the t-stat again.
  4. jshadwick
    Jun 24, 2001
    45
    Sacramento, CA
    Thanks, I will. Come to think of it, I had changed the intake manifold gasket at pretty much the same time (it was leakin'). I wonder if that could have messed with the timing... /forums/images/graemlins/ooo.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Let's see, to swap the intake manifold gasket you had to remove the distributor. If you didn't check the timing after reinstaling the distributor, then there's a 99.99% chance that the timing is off. Set the timing to spec and the pinging will probably go away. /forums/images/graemlins/cool.gif
  6. jshadwick
    Jun 24, 2001
    45
    Sacramento, CA
    Dang, the timing was good.
    Also, I think that it pings when it is warmed up.
    For the sake of testing, I gunned it getting on the freeway when it was not fully warmed up(Im about 3/4 mile away from freeway) , and no ping. I didnt like doing that...but it seems to confirm my theory. If I had the time, I woulda just changed the damn thing today and be done with it...
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    you can retard the timing a few degrees and it might help with the pinging.it helped on my truck.
