Changed tranny pan gasket and filter, Put 5 quarts of ATF back in........??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silver84k5, Jun 16, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    wont go into gear and i cant really see the level on the dipstick, how many quarts should it take to get it to go into gear? oh yea its a th350
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    if i remember right...around the 10 quarts area is about right... /forums/images/icons/confused.gif
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    AUTO PARTS PEOPLE ARE RETARDS
    grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr i didnt know how much should go back in, so i listened to his dumbass, although it didnt seem like 10 quarts came out when i took the pan off, the torque converter should still be full right?
  4. Chaz88K5
    2,979
    Stockton/Lodi CA
    it should be...but 10 bucks says the rest of the tranny is not full yet /forums/images/icons/smirk.gif
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Whatever the parts guy said was not in quarts, it's in pints.
  6. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    Everytime I drop the pan on my tranny, I am surprised at how much fluid it takes to fill it. My chiltons says something like 5 pints. Yeah right. I buy my ATF in the gallon and it usually takes one and 3/4 (about 7 quarts) to fill it back up. I just fill it up a bit, start the truck, and keep filling until the level is right (periodically shifting in and out of gear to get the ATF going everywhere).
  7. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I'ld think if your running a tranny cooler, that would increase volume of atf needed to fill. I just keep filling mine until the dip stick says full. Run it through gears and recheck.
    tom
  8. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The tranny cooler DOES indeed increase the amount of ATF you need to refill it. I installed a big stacked plate cooler and now it takes almost one extra litre to reach the full mark after a service.
  9. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I are a auto parts retard and but I don't have to call to find out how much fluid to put back in.
    jIm
  10. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    When i change out the filter and gasket on 350s at work i put in about 5 quarts . It may have been low before you took it apart. The converter usually doesnt drain when pulling the pan .
  11. BlazingItaly
    BlazingItaly Registered Member
    Apr 7, 2000
    35
    Milan Italy
    When I did my oil change I put 10 quarts and a little overflow from the pan.
    Do it a quart a time and see how much you need.
    Luca
  12. SWAMPRNR
    Apr 7, 2001
    296
    Temple Texas
    How did you get 10 quarts in by just pulling the pan ?
  13. Grim-Reaper
    7,385
    Atlanta
    Fill it till it shows on the dip stick. Then fire it up and it should be about enough to run on. Not sure what tranny you have but on My TH350 it usualy only takes about 3.5 quarts with a change.
