changin the diff fluids
Discussion in 'The Garage' started by NEK5, May 17, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    just want to get a general idea of the process as i`ve never done it before and plan on it tonight
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    drain fluid, refill to bottom of drain nut. easy as pie
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Rear:
    Put a drain pan under the axle. Unbolt the diff cover. Usually I like to leave the upper most bolt in a few threads(so the cover doesn't fall into the drain pan). Use a screw driver or something and pry the cover away from the housing. Let it drain. Check the magnet(if there is one, should be in the bottom of the diff or on the cover) for debris and metal. Clean off any shavings, if there are big chunks, well look for damage on the internals. Clean the mounting surface off. Install the gasket on the cover or silicone on the cover or housing. Black or Grey will work(either is oil resistant). Install the cover. Remove the fill plug. It is on the pinion area on the front side of the axle. Look for a little plug that has a 3/8" square drive. Stick in a 3/8" extension and use a ratchet to remove it. Fill through the hole.
    Front:
    Same as the rear just the fill hole is on the cover.
    Sorry if this insults your intelligence with simplicity.
  4. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    Remove fill plugs first. If they don't come out it will be very difficult to fill after you drain the diffs. Remove cover bolts. Remove cover. Light prying may be needed. Clean gasket surfaces on diff and cover. Reinstall covers with new gasket or sealer. Refill with your choice of gear oil to bottom of fill hole. Install fill plug. Cold beer may be needed between some (most) steps.
  5. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    not to sound like a douche or anything but you should buy a haynes manual to help you out with alot of the basic maintnence on your truck.
  6. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    simply unbolt the diff cover, let the fluid pour out.. then get in there w/ a rag and clean out the old gunk, then put a bunch of rvt sealant on the diff. cover, and bolt it back in.. open the lil drain plug and re-fill till new fluid pours out. there ya go.
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    should i get new gaskets or buy the liquid silicone stuff???and what gear oil should i get???
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    so what do i tell my mom if she catches me?
  9. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well i do have one, its just under a whole bunch of crap in the shed and i am REALY lazy
    didnt mean to make it seem like i wanted everyone to tell me everything, even the basics
  10. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    Definitly need a Hayne's or Chilton's manual, they cover all this little stuff in depth.
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    :D:D
  12. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Some use RTV, some a gasket. I use both - a thin coat of RTV and an OEM gasket. Most probably just use RTV.
  13. cbbr
    Jul 17, 2004
    14,681
    That you were just following instructions......
  14. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    gear oil?
  15. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Go buy some brake cleaner(once can per diff). Once you've got the cover off and all the fluid drained out, use the entire can rinsing everything down inside the diff. After you're done, scoop out all the gunk that will have accumulated on the bottom and leave the cover off for at least a half an hour so that any left over brake cleaner has a chance to evaporate. When you're sure that everything is dry, button it back up and refill it as per everyone's directions.
  16. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    X2 :D That's how I do it every single time. Brake cleaner is a life saver for cleaning up old oil and lubricants.
    Rick
