Changing 12 Bolt Pinion Yoke
Discussion in 'The Garage' started by csnutrition, Apr 4, 2005.
  1. csnutrition
    csnutrition Registered Member
    Jan 8, 2003
    16
    North Alabama
    What difficuly level is it to replace rear pinion yoke (12 Bolt). The rear U-Joint cap is slipping within the yoke. If you loosen the Pinion Bolt and remove yoke, does it effect the backlash any? How difficult is it to remove and reseat the yoke? etc.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You are supposed to reset the gears after removing the yoke , that is the proper way . Use a new crush sleeve .
    Now however some of us have been able to do it without resetting , myself included . We could of been lucky .
    Mine is just cranked down as tight as it can go .
    So far it isn't making any noises , nor is it running hot .
    Luck is friendly to poor people sometimes :k5: :k5:
  3. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    mark the nut and count the treads showing on the pinion. Retighten to that same mark. Since you are using a different yoke it may not be excact, assuming that there are manufacturing differences. The crush sleeve will take more torque to crush more than it will be to install a new yoke. I have had good luck replacing pinion seals without resetting pinion bearing preload. i.e. installing a new crush sleeve. My suggestion is to tighten until you feel the crush sleeve contact the yoke. Make sure that the pinion with yoke bolted on does not "walk" in and out. Good luck.
