changing a coil axle to leaf spring
Discussion in 'The Garage' started by bad_bo_ti, Apr 27, 2005.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    can this be done and how hard would it be, i am thinking of going sas on my 93 chevy my buddy has a ford f150 with coils he said he would sell me the axle cheap. i was wondering if it could be converted to leaf or would i be better off leaving it coil? also what year did they start putting disc on the 44 with the open knuckle? thanks, chris
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Sure, you can cut/grind all the coil crap off of it and weld some perches on top. I forget where to get them, I think maybe DIY4X4.com would have them.
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Done reasonably well coils will ride better than the best leaves.
  4. bad_bo_ti
    1,027
    OhiO
    would it be any harder to set up than leafs?
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Get the upper coil pockets off the truck from your friend.
  6. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    I think leaf springs would be easier to set up, but that's just me. Coils are definitely doable, and since you're starting from scratch anyway, it's all up to you.
  7. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Depends on how trick you want to make the linkage. For anything beyond a radius arm/tracbar system you'll want to consult ExcelCAD (search this name) for the linkage geometry.
    Keep in mind that for 'cross over steering', i.e. draglink across the width of the truck, that you'll really want to use a tracbar for lateral axle location. This will allow you to tune the bumpsteer.
    With a radius arm/tracbar design there are just two things I consider important.
    1)Put the radius arm frame pivots where you'll get the least plunge in the front driveshaft. (shortly will be able to 'fool' ExcelCAD into helping with this [hint, hint]).
    2) Bumpsteer. Ideally the tracbar and the draglink are the same length and parallel as viewed from the top and from the front. If they aren't, then you'll need to fiddle the pivot points (usually of the tracbar) so that the different travel arcs overlay each other within the travel range as much as possible.
    With leaf springs the ideal draglink is very close to level with a *slight* down-slope to the right knuckle. With a tracbar the draglink can be any angle that the joints will work at as long as the tracbar is as stated above.
