Changing a V6 to a V8 in a '94 questions
Discussion in '1992-Present Chevy & GMC models' started by Sandman, Jan 30, 2003.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Changing a V6 to a V8 in a \'94 questions
    Has anybody done this? We have the doner truck and was wondering if we could get away with like the wiring harness or what kind of surprises we might find. Thanks.
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Re: Changing a V6 to a V8 in a \'94 questions
    What type of fuel system is on the donor truck? The '94 that you want to swap the engine into should have TBI. If the engine you are putting in it is the same system, the wiring harness will be the same, both engines use the same sensors. You should be able to swap the engine in, hook up the wiring, and swap the ECM from the V8 truck in. the ecm from the other truck will have been programmed for the transmission and gear ratio parameters that were in the donor truck, if these are different you may have to get a special chip to correct these settings.
  3. aahomerepair
    aahomerepair Registered Member
    Jan 31, 2003
    35
    Springfield,MO
    as stated on the above post if the wiring and fuel system
    is the same and the drive line is diff.you won't need
    to get any special chips,use you oem ecm and just change
    both removeable chips and this will take care of it.
    did 350 swap on 88 astro van and spent alot of time
    trying to get it right and that is all it took to
    get the computer working right.after spending 500
    on computers and chips and it is one bad a$$ set-up
    sorry about that poeple some times i need /forums/images/graemlins/1zhelp.gif
