changing a yoke on a 203
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beater74, Oct 8, 2002.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    So got this new rear CV 1350 shaft from Jesse, so i gotta install an new rear output flang on my 203. My question is, is it a simple as taken off the old and putting on the new with a little locktight? or is there a proper torque or anything else that needs to be done?
  2. Grim-Reaper
    7,385
    Atlanta
    That's pretty well it. 80-90 lbft should be plenty if the crush nut is not doing the trick.
  3. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    When I pulled mine, it was a major PITA. But every truck is different. I think it is a 1 5/16 socket. I had to use an impact wrench on mine, the 3/4" drive ratchet wasn't the right tool. As far as simple, yes, off and on. Just make sure everything is lined up correctly (yokes, u-joint allignment) or it's gonna shake like a mutha.
