changing alternator belt on 88?
Discussion in 'The Garage' started by muddybuddy, Apr 11, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey guys, i have an 88 k5 (multi belt drive), and i need to change the alternator belt. i know how to losen the alternator belt, but how do i get the other belt off that is infront of it? its in the way. do i have to take the fan off to change the belt? thanks guys.
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    If its a single belt system you can use a socket on a ratchet to release the belt tensioner. Be careful a a/c mechanic would not listen to how its done an the thing unloaded hitting him square between the eyes. It looked like he got hit by Mike Tyson :rotfl: They make a tool to use also.
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    does multi belt sound like single belt? :haha: :screwy: ... assuming you have a smog pump you need to loosen the bolt that is holding the smog pump in place...should be a 9/16 IIRC. just loosen it take the belt off then shimmy the alternator belt off.
