Changing Antifreeze 6.5 TD
Discussion in '1982-Present GM Diesel' started by jac6695, Aug 18, 2003.
  1. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Is there a way to drain the block on my 97 6.5 to drain all of the antifreeze out of the block? Or can I just drain it from the radiator/lower hose? I plan to pull my radiator in the next couple of days to change the coolant and to clean all of the bugs and debris from it and the oil coolers. Thanks, James.
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    i think the coolant drains on the block are behind the motor mounts.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I usually just back flush it by tapping into the heater return hose.
