Changing backspacing on runflats
Discussion in 'OffRoad Design' started by coloradoblazers, Aug 10, 2002.
  1. coloradoblazers
    coloradoblazers 1/2 ton status Premium Member
    Mar 2, 2001
    506
    WY
    I am getting hummer wheels, and I was wondering if ORD can move the centers to change the backspacing. Where else might I check to have this done?
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
  3. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Making the centers is not the hard part. For approx. a 3" backspacing the center needs to be close to 15 9/16". You can make a jig using a spare 16.5 wheel and all thread to set the back spacing. Tack the wheel center in place, then weld it in on a metal lathe to make the sure the center is perfectly in place. You must sand blast the inside of the wheel very good to remove the ceramic coating around the mild steel that makes them bullet proof. Otherwise, you can't weld it. Find the biggest plasma cutter you can find to cut out the old centers. You most likely wil not be able to cut them w/ a torch. PM me if you have more questions.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    tru design wheel in denver might be able to help you out, I've heard their name mentioned with several custom wheel projects.
    We probably could do it, I think the lathe might be big enough but it's a ways outside our normal job so I wouldn't take it.
  5. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Or, you could just hire me to run the lathe and weld when I move out to Golden on Fri. /forums/images/icons/wink.gif Can't wait. Mines will be a vacation compared to the last three months of pulling 70+ hr. work weeks.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'm not sure you could call 'Mines a vacation from anything! It's a heck of a commute from Golden to here, that might not work out so well!
  7. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    If you're running a dana 60, dually bearing hubs might give you the spacing you need. Dually rear ends are also wider, and would probably need a small spacer to square the rear with the front. The dually bearing hubs can usually be gotten pretty cheap as most people are looking to go the other direction, i.e. dually to single wheel. BTW good luck at Mines, I am class of '94, Mining.
