changing ball joints..
Discussion in 'The Garage' started by k5floyd, Feb 3, 2007.
  1. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    im going to change out the ball joints on my 10b. i know im going to need a ball joint press and will get that very soon. i know i can do it ive just never done them before. it looks like you got to take a lot apart to get to them. so my question is what all do i need to take off to get to them? any other tips? thanks.
  2. goldwing2000
    goldwing2000 Guest
    You have to take everything off all the way down to the axle housing.
    In addition to the press, you'll need the spanner socket to set ball joint preload, a wheel bearing nut socket and a 1 5/16" socket for the nut on the top joint.
    Other than that, all you need is regular hand tools (but air tools help a lot) and some patience.
    Oh, and you'll probably need a dead blow hammer or a hunk of hardwood to get the spindles off.
    Might want to change your axle joints while you're in there.
    I had a web site bookmarked with the procedure all spelled out but I think it's on my work computer. :doah:
  3. dremu
    Feb 27, 2000
    15,952
    444
    East of San Francisco
    Use the search button -- you paid for it =))
    http://coloradok5.com/forums/showthread.php?t=197818
    -- A
  4. goldwing2000
    goldwing2000 Guest
  5. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    ok so i cannot find the spanner socket anywhere. well i havnt tried matco or any of the other tool companies but i wouldnt get it this weekend wich is what i need. my intructors at school did not have it, and our tool room did not have it. i tried oreillys and they didnt know anything about the adjusting sleeve or the spanner. i stopped by my work and only a few guys knew anything about the adjusting sleeve and nobody had the socket either, i also checked our tool room and had no luck. if i cannot find this spanner socket this weekend, i will try matco or another tool manufacturer. so anybody have an idea where i can find this spanner socket this weekend? that is all that is holding me up right now.
  6. dremu
    Feb 27, 2000
    15,952
    444
    OTC 2080
    http://www.otctools.com/products/detail.php?id=2295
    NAPA has them, for instance. Or, if you're clever, you can make one with a grinder and the appropriate OD socket. I had better luck buying one :doah:
    -- A
  7. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    Do a search on ebay for BALL JOINT SOCKET/SPANNER
    There's a bunch on there. It's where I got mine too.
  8. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    we dont have a napa around here, that i know of, but i guess i will look up the closest one. other than that i guess i will just have to wait on it. thanks.
  9. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I got mine from snap-on. pricey but I will have it forever. I have used it at least as many times as dollars I spent on it.
    there is a guy liquidating a snap-on truck on Ebay. check there.
  10. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Have you tried THIS (click) to see if it has the socket you need?
    In case the link doesn't work. The part number is T75819
  11. goldwing2000
    goldwing2000 Guest
    I got mine from a local auto parts store that carries OTC tools. Call around.
  12. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    Doesn't one of the ball joint nuts require a pretty big socket? Like 1-5/16" but maybe I'm remembering wrong.
    Ditto on the ebay source for spanner sockets. I've run across them there.
    I just took my knuckles to a mechanic to press the joints out. It was $40 for both IIRC.
  13. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    yes.
    I use a combination wrench, that way I can beat on it with a hammer. poor mans impact. I don't have a socket that big.
  14. goldwing2000
    goldwing2000 Guest
    Yep. Go back and read post #2.
    I bought the socket from Sears but it was 3/4" drive, so I also had to get a 1/2-3/4 adapter.
    You can borrow a ball joint press for free from Autozone and save yourself $40.
