Changing brake shoes
Discussion in 'The Garage' started by adamforsythe, Mar 12, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    How hard is it to replace brake shoes?
    Adam
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    easy. Get brake spring pliers, some skrewdrivers, and pliers and put it together the way it looked before. Do one side at a time for reference. If its a 14 bolt, do disc brakes, about the same price (maybe a little more) and well worth the extra labor.
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    Semi floater axle = piece of cake
    1. Remove Wheel
    2. Remove drum
    3. Tear apart
    4. Reassemble and done
    Full floater is a bigger pain, have to remove axle shafts, remove hubs, then tear down and reassemble, then finally refill gear oil
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    its easy. Like said, only do one side at a time. The worst thing you can do is have a buddy help and both of you tear into both sides at the sametime. Refering to the other side is the easiest way to put it together.
