Changing Dash Lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MrBob, Feb 7, 2001.
  1. MrBob
    MrBob Registered Member
    Jul 27, 2000
    52
    I'm sure I'm not the only one who has done this but it is amazingly easy for us novices. I thought you would have to take the entire instrument panel out to do this. Not true. All you have to do is get the plastic glass cover off and the black panel that covers the instrumets themaselves and you will see that the lights are plugged in easily accessable for replacememnt when yours burn out like mine did. Chiltons nor haynes makes comment how simple this is nor do they give instructions. I'll try to remember to get digital pix this evening for anyone who might be interested. So thei entire instrument cluster doens't need to be removed. It was also interesting that t most of the guages are plug ins too and not directly wired to anything. Mine's an '86 K5 305.....
    Red Springs, N.C.
    "I ain't responsible for my crappy typin' or spellin'"
  2. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    a perfect tech article, methinks. steve (mr. coloradok5) is looking for informative tech articles, on real world stuff. like changing your burnt-out dash lights!
    he's offering two small and one large CK5 sticker.
    also a way for us mechanically-challenged people to contribute to the board....
    <font color=purple>delta9blazer</font color=purple>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You don't have to even remove the front glass. You know those little sockets that the bulbs were plugged into?? They remove from the backside of the cluster with just a quarter turn. [​IMG] You can reach up from under the dash to get at 'em.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    Harry is right. All you have to do is take out the HVAC duct (if you have one) that runs over to the drivers side vent so that it is not in your way. Then just reach up through the mess of wires and unplug the little socket. Then the whole thing removes with no wires attached. Put in a new bulb, clean the contacts to reduce "flickering" and plug it back in.
    If you are going to go in through the instrument cluster, it is easier to pull the cluster forward then it is to remove the clear plastic and then take out each of the gauges as needed. Just reach up behind to unclip the speedo cable and the cluster will come out.
    <font color=blue>5-lugs: The sign of true weakness.</font color=blue>
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I just liked pulling out the whole cluster better. That way I could clean all the plastic, clean the rear contacts and adjust the bulb holders that were loose. I also straightened up the wires behind the panel. Its a pain getting it to all come out though but it kept me entertained. Taking the glass off makes one or two bulbs alot easier project. You can get most of the bulbs out by hand but its harder I think. You have to remove the vent tube and you have to dodge the steering column and the whole nine yards, its pretty frustrating.
    June 2001 - The Texas Sawz All masacre begins. Be afraid rust, be very afraid. [​IMG]
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The problem I've found with taking the dash apart for anything is that each time it comes apart, the plastic that the screws go into gets a bit more wallowed out. Over time the dash starts to rattle and squeak. I don't go in there unless I absolutely have to. [​IMG]
  7. MrBob
    Jul 27, 2000
    52
    Isn't it interesting how none of the manuals describe this? I jsut found this out by pulling and taking off...the behind the dash pull 'em out would have been easy.
    Thanks all
    Red Springs, N.C.
  8. MrBob
    Jul 27, 2000
    52
    Thanks all
    Red Springs, N.C.
