changing from 10 bolt to dana 60 front...
Discussion in 'The Garage' started by xpndbl3, Apr 17, 2007.
  1. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    Bough a DRW dana 60 out of a 82 dually, I'll be ordering the SRW hubs and rotors shortly. Right now the suburban is on a 6" lift kit and has a raised steering arm, I believe it's called. The dana 60 has kingpins, so can that steering arm be transferred over or what is needed to be swapped. Right now it's an 88 3/4 ton suburban with the 8 lug 10bolt front. I'm guessing the stainless brake lines that I have would swap over to the dana 60 calipers as well?
  2. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    Crossover steering would be the best thing you could do for your steering, otherwise you will need to get either a steering block , to raise the stock arm on the Dana 60 + either a dropped draglink ,or a dropped pitman arm to get some kind of steering, which will still be poor on the road & even worse offroad. Then you'll realize that you should have just went with crosover steering in the first place . Then you have all those parts left over ,when you finally go to crossover & can't get even 1/2 your $$$ back by selling them . (ask me how I know):doah:
  3. xpndbl3
    Jul 30, 2005
    510
    orland park, IL
    which crossover steering did you go with? Plus I don't know of a local shop to do the machining to the spindle since I assume they all need machining for crossover steering.
  4. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    X2
    I'm using ORD on mine.
  5. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
    I went with ORD (I got a deal on some used stuff) ,but there are a ton of other vendors with quality parts.
    Pony up the $25 & become a member (you will not regret it) Then you can use the search function & open up a whole different world of information.
    Just the amount of knowledge & skill on this site overwhelming .
    Notice of Disclaimer. Any reference to a commercial product, process, service, or company is not an endorsement or recommendation by CK5 or ORD
