changing from 33's to 35's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Jul 21, 2001.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    changing from 33\'s to 35\'s
    i just recently bought new 33/12.50 geral muds, and ran across a great set (look brand new) of 35/12.50 all terrain, for 250.00, plus i have a buyer for my tires for 300.00. was just wondering if i would regret the siae change with 4.11 gears
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  2. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    Re: changing from 33\'s to 35\'s
    i would say no, you wouldn't regret it. friends got 35 SSR's and loves it on the 4.10s
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Do it. You'll need a 4" lift if you don't have it already.
    Dave
    If You Drink Don't Park, Accidents Cause People.
    91 K5 - in the process of 4" lift with D60/14FF plus LOTS of extras. ETF August 1.
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I got 4.10's and 35's and I really like the combo. man, I'd definately jump on it.
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If yur running a 700r4 i would definatly get some taller gears. Somewhere around 4.88 to 1. If you keep the 4.11 dont use overdrive. Big tires and not enough gear is the fastest way I know to cook a 700r4.
    <font color=orange> You are just jealous, because the voices only talk to me.</font color=orange>
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got a 700R4 and 4.10s and 35s, and 2000 RPM is plenty to cruise at, 65 MPH. My truck is geared at least 25% lower than stock gearing is, if not more than that.
    My truck came with 2.73:1 gears and 235/75R15s from the factory. 4.10s and 35s are plenty. As long as you're over the stall RPM, you're safe.
    Tim
  7. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    I Have had both on my truck, can't really say I notice any difference, also have the 4.10's, however i have te TH465, which might be a different story... Anyhow, with the 4" suspension and the 3" body, it looks better with teh 35's . but just my opinion!!
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear, dana 44 front, TIRED ol 305
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    SM 465 or TH 400?
    Any pics of your setup? My buddy has 38s with that lift.
    Tim
  9. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    4.11 should be good, that is what i have with my 35s and a 700r4.
    Jump on it!
    if your deal falls through for the 33s let me know, i need a set for my wifes jeep.
    Go heavy or Go home[​IMG]
  10. blazerbum
    blazerbum Registered Member
    May 14, 2001
    96
    lake stevens washington state
    i was told id need at least a 4 inch lift on my 73 to go from 33's to 35's but with the 4.10s it will be reall nice and i could use the same rims 73 k5 350,tb350 .33's 410.
  11. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    You will definitely need at 4" of lift for your 35s, but I think your gearing will be okay. I am running 35s on mine right now with 3.73s and it does okay. but I am upgrading to 4.56s since I have a weak ole 305 motor. You should be fine. If you pass it up, you will regret it later!
    85 GMC Jimmy <a target="_blank" href=http://tx85gmcguy.alloffroad.com>tx85gmcguy.alloffroad.com</a>
  12. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    4 inches with 35's is a sweet setup...
    Mine is 4 inch lift, 3.73 Gears, 35 inch tires on 10 inch rim's..
    They will rub... Mine are rubbing like crazy when I tried flexing the suspension... Front tires are the one's that rub..
    Might want to trim your fender's if you go w/ 35's.. or a 1 inch ORD Body lift.. (my next purchase).
    A well armed society is a polite society.UPDATED <a target="_blank" href=http://www.rocko.rockcrawler.com>www.rocko.rockcrawler.com</a>
  13. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    i really do not want to go up 4 inches. i do not do any rock crawling, basically because if you see a rock anywhere around here they brought it in on a truck. and i would like to keep the lower profile look. with the 33's i do not rub at all, and i only have 8"rims, and besides if i do find i rub could i not get away with a 2" add a leaf front and rear to make up for the larger tire?
    what's in it now?
  14. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I was running 35x14.5 Boggers with no lift for a little while with some minor fender trimming in the front. It would rub on full turns but other than that, had no problems.. on road only. Since the 35's you want to get are 12.50 wide, I think you should be fine with a 2" lift... cause it sounds like your rig doesn't go offroad anyway. Go for it.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers... and it's still not BIG ENOUGH!!
  15. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    me and some guys do go offroad, but offroad around here seems pretty tame compared to what gets posted. besides its mostly all mud, not to muck flex needed. did have to call the wife to bring the f-350 the other day to pull my son and i out of a mucher deeper than appearing mud hole
    what's in it now?
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I do all mud and my tires rub with a 4" lift. If you don't want to lift it, don't get the tires.
    I don't do anything even close to what these guys on here do, but I do offroad quite a bit.
    If you don't want to lift it and do it right, stick to 33s.
    Tim
