Changing from np208 to np 203/205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by az84chevy, Jul 5, 2005.
  1. az84chevy
    az84chevy Registered Member
    Feb 17, 2004
    69
    How hard is it to change an np 208 mated to a 700 r4 to either of these? I may have found a 205 for a good price and want to now how hard it would be to change over.
  2. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    what you'll need is a np205 with factory adapter and crossmember (unless you want to build your own) that came from the factory in a th350-to-np205 chevy truck. Then you buy a $50-ish spacer (search). Basically, the output shaft on the 700 is just too long... so the spacer takes up some of that un-needed length. You do need to trim about 1/8" off the output shaft of the 700... and will probably need to drill some new holes in the frame for the x-member and modify the shifter so it'll come through the floor in the right spot... but other than that its a bolt-in-and-go swap.
    j
  3. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    also the spacer helps clear the tranny pan with the frt drive shaft.
