Changing from standard to auto in a 1st gen K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazin72, Feb 27, 2001.
  1. blazin72
    blazin72 1/2 ton status
    Oct 24, 2000
    279
    Oklahoma
    What do I need to look for when changing from a standard to automatic. I have a 71 With a 350 turbo and Np 205 that I would like to put in the place on my 4 speed and 205 in my 72.
    Can I leave the transfer case or is the splines different and what about drive shaft? What do I need to look for to be a problem.
    I am tired of shifting I know the 4 speed is a hell of alot better but i am getting lazy I guess.
    Thanks for all the help
    Blazin 72
  2. fastzilla
    fastzilla Registered Member
    Feb 12, 2001
    20
    Dallas, TX
    The SM465 vs of the NP205 is a 10spline(100% sure), the TH350 vs NP205 is a 27 spline(90% sure). The t-case will need to be swapped too. Its easier to go from manual to auto than the other way. Might need to get the column shift stuff unless you plan to use a floor shifter. Pedals maybe, the clutch pedal can be unbolted by the pivot and removed leaving the small brake pedal, if you don't mind that. The SM465 is 12" from back of bell housing to back of trans, not including the adapter between the trans and t-case. You 've got them both there so you can measure, the front and rear output yokes are the same on the 2 NP205s so the lenght is the only issue... Good luck.
    Eddie
  3. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    Do you wanna sell your sm465 and transfer case? I wanna swap out my th350/205 for a stick
  4. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    You will also need to swap the radiator so that you will have a trany cooler.
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
  5. blazin72
    Oct 24, 2000
    279
    Oklahoma
    Thanks for all the info.
    Roostr84 Do you have any idea what shipping would be to oklahoma. There might be a possiblity. What kind of shape is your tranny and transfer in.
    You can e-mail me we can talk send it to hforrester@datalinkok.com
    Blazin 72
  6. fastzilla
    Feb 12, 2001
    20
    Dallas, TX
    From NJ to OK.... Forget it ... Head south on 35 for a few hours to Dallas and pick up the combo for $200... UPS will ship up to 150# anywhere in the states for $61.50, according to their pricing charts... The NP205 without adapter is 135# and the SM465 is a he!! of a lot heavier...
    Eddie
