changing front and rear diff fluid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85chevy4x4, Sep 17, 2002.
  1. 85chevy4x4
    85chevy4x4 Registered Member
    Apr 26, 2002
    63
    kansas city, kansas
    I'm going to change the fluid in my front and rear differential tonight. It has a 10 bolt front and a 14 bolt full floater in the rear of my 85 chevy 3/4 4x4. What is involved in changing the oil? What do I need to use? How much does each hold? /forums/images/icons/confused.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Simple. Put a drain pan under the differential. Take all of the bolts out except for the very top one. Losen that one a couple of turns. Then just pry off the bottom of the cover and all of the fluid will drain out. Once the fluid is drained, take out the top bolt and take off the cover.
    Use SAE 80W-90 GL-5 gear lube.
    Make sure when you put the cover back on that you scraped off the old gasket and either replaced the gasket with a new one or that you use rtv sealant.
    Capacities - 14 bolt? 10 bolt I think something like 2.5 quarts. Man I wish I had my Chiltons with me at college.
    Hope this helps.
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    What he said /forums/images/icons/grin.gif
    But when you do, you might wanna take off the covers and just inspect for any type of unregular wear or any metal shavings inside...fillup hole for rear diff is on the front side on the passenger side of the driveshaft. And the front fillup hole is on the diff cover. hope this helps
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yeah, do the inspection, but since you have to remove the cover to scrape off the old gasket anyways, it's not like it requires any more work. </font color>
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    And before you refill your diffs, use some BrakeKleen and spray down the inside of your diff. BrakeKleen helps break down any sludge that's built up in there. I use one can per diff. Make sure you clean out the inside really good and let the leftover BrakeKleen evaporate, because if you put in fresh gear oil too soon, any remaining BrakeKleen will start to break the oil down.
  6. 76k5Blazer
    76k5Blazer 1/2 ton status
    Sep 25, 2002
    176
    tracy ca
    an engine cleaning air spray gun and gas works good too.
    Thats what we used when i worked at a diff shop to clean out the housings.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I used Diesel fuel in a poison sprayer (hand pump tank thing like you get at Home Depot) to flush mine out nice and clean. I'm not sure if the inner seals on the front diff would like the brake clean. Probably wouldn't hurt them but, I don't know what the seals are made of or how resistent they would be to solvent that "hot"...
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    My D44 holds almost a gallon on its own. My 12 bolt is around 3 quarts. If I remember correctly, when jekbrown did the his D60 and 14bolt, he used a gallon for each diff.
