Changing front wheel studs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by EDdaTREE, May 14, 2000.
  1. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I've got 3 bad lugnut studs on my front axle...the lugnuts won't tighten up. I changed the rear ones before using the old "knock em' out with a hammer and pull the new ones in using washers and tightening the lugnut" method. How hard is it to do the fronts? Do I have to just pull the hub and rotor assembly off the spindle? Or do I have to split the both of them? Or is there a way to punch em' out still on the truck? Thanx for any help, and HAPPY MUDDIN'
  2. Todd78/87
    Todd78/87 1/2 ton status
    Feb 18, 2000
    436
    Haines, Ak
    Do them the exact same way as you did the rears,, just pull the tire,, knock them out the back and suck 'em in with an impact wrench.
    Todd 78/87[​IMG]
    Alaska Bound
  3. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    you have to pull the hub down though too!
  4. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Yes you have to pull the rotor off the spindle to do this.I just did all six on one end when i lost my wheel.Not good!!Brady
  5. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Brady is right. We had to replace all mine in the front before we slapped the 35's on my Jimmy. You have to remove all that stuff to get to them. Then after that you just punch them out and put the new ones in. Good luck man!
    Alex
    Wichita, KS
    What me get stuck? NEVER!!(Famous last words)
