Changing Fuel Pump And Sending Unit
Discussion in 'The Garage' started by blazerguy 90, Oct 9, 2005.
  1. blazerguy 90
    blazerguy 90 1/2 ton status
    Nov 12, 2004
    126
    EL Sobrante, CA
    I need to change the fuel pump and sending unit on my 90 Blazer, how hard is it to do ?, ive never done anything like this before, is this something I can do in my drive way in a day ???.
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    It6's really not too hard at all but you do have to remove the gas tank.
  3. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    NOT a fun job. Did it on my '90. Yes, the gas tank has to come out. grrrrrr
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    hope the tank is nearly empty, easier thay way :doah:
  5. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    I did it the lazy man way and did not drop the tank.
    I made a access panel in my bed, then i had to bondo the top.
    After putting the herculiner on it doesnt stand out at all.
    But if i had a chance to do it again i would have dropped the tank and do a shackle flip at the same time :crazy:
    added two pics of bondo fix before herculiner
  6. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    I also cut a 12"X6" access panel in the back of the blazer to get the sending unit out. It was a lot easier the dropping a 3/4 full tank, reciever hitch and flatbacking it by myself. I used a sawsall blade that i cut down to be 2" long as not to cut into anything vital, then tacked some tabs a remounted the cut out plate w/ some screws.
  7. badfish4tail
    Mar 1, 2005
    1,684
    Long Beach
    :eek1: Your pretty brave with a sawzal, I used a dremul :D
  8. dyeager535
    26,982
    191
    You might be able to repair the sender depending on what the problem is, fixes have been posted to the board before. The senders are quite pricey.
  9. blazerguy 90
    Nov 12, 2004
    126
    EL Sobrante, CA
    Thanks guys, when I got my Blazer the sending unit was bad, now I think my fuel pump is starting to go out (149000 miles) so its time to replace both. I got the sending unit from LMC Truck, it was 99.00 dollars, I got a new fuel pump for free so this isn`t costing me as much if I would have had to by both parts.
