Changing GEAR oil????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ED70K5, Jun 13, 2000.
  1. ED70K5
    ED70K5 1/2 ton status
    Apr 28, 2000
    179
    Texas, USA
    What kind of gaskets should I use when I change my DANA 44 and 12 bolt gear oil on my 70 K5?? I have never done this myself and want to save some cash on the labor. Anything special I should do?? Any first-timer tricks or tips I should know of???? What kind of gear oil should I use?? Sorry for the elementry questions, I always went to a shop to do this. Now I'd rather do it myself!!
    Blazin' in TEXAS!
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I just go to Pep-boys or AutoZone and ask them for a gasket for a 10-bolt(or in this case a D44 & 12 bolt). I use Valvoline 90W gear oil.
    http://www.blazer.coloradok5.com is now under construction[​IMG]
    YEEEE HAWWWW[​IMG]
  3. Todd78/87
    Todd78/87 1/2 ton status
    Feb 18, 2000
    436
    Haines, Ak
    You don't even need gaskets if you don't want to use them. Just get a tube of Black RTV silicone. Read the other post,, "Can't get Diff to stop leaking"
    Todd 78/87[​IMG]
    Alaska Bound
  4. Oil Man
    Oil Man Registered Member
    Apr 25, 2000
    27
    Santa Clarita, CA USA
    You could use any gear oil but if you want to use the best then call Mag-Hytec and order the LE #607 SAE 90. Tests have shown that the LE oil has 33 times wear than even the Amsoil 75w-90 synthetic gear oil. Mag-Hytec's number is 1-818-786-8325 or www.mag-hytec.com
    Sincerely, Kevin
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I don't use the paper gaskets at all on the diff covers. A light coating of RTV (I use black because I don't like the look of the blue stuff around the edges) seals it up great. Just be sure to get the very bottom edge grease free (gear lube seems to ooze out of the housing for hours!). I wipe out the bottom of the diff housing with a rag, clean the sealing edge and slap the cover in place while everything's clean. Haven't leaked a drop in years.
    http://ThunderTruck.ColoradoK5.com
