changing gear ratio???????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Jun 19, 2003.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    What parts do I need to change in order to change my gear ratio? How much shoud I expect to pay to do this?
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I'm guessing but haven't actually done it yet...if 4wd you need to change front and rear gears...with parts at say $150 a set = $300 and labor lets say a conservative $250 for both axles you are looking at around $550....I was thinking about getting my 2.76s swapped out but it will be the same cost or cheaper to go to 4.10 3/4 ton axles.
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    edit- the below is per axle -end edit
    a little low there. mine cost $160 for gears, $100 for install kits and normally labor goes for around $200-400 per axle.
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i think txbluethunder is closer. mine were $200 & $250 for gears $150 ea for installs & 325 & 500 for lockers. i did the laber but average cost around here is $300 an axle.
