Changing gear ratios...
Discussion in 'The Garage' started by PhoenixZorn, Sep 25, 2005.
  1. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    LMC Truck catalogue has me worried now... I have a D44 front and a 12-bolt posi rear end in my Blazer, and I found it has 3.08:1 gearing. Now, with 33" tires, this is all fine and dandy, I run at fairly low RPMs on the highway with my TH350, but eventually plan on swapping out my SM465. I also plan for a future 35" tire upgrade, so the 3.08 gearing will be somewhat lacking. I would like to go with 3.73s or 4.11s, but its my understanding from reading the catalogue that if I do that swap, I need to get a new rear differential case as well as the new ring and pinion set.
    Can anyone shine some light on this subject?
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    cases? no
    carriers? yes
    Junkyard carriers for 3.73's shouldn't be all that hard to find.
  3. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    am I going to be able to find the a carrier that had posi though? or doesn't it matter...
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Doesn't matter if it's posi or not. Posi and non posi carriers are the same externally in relation to R&P mounting.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    why not just go with thick gears?
  6. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Even better get a Detroit!!! :waytogo:
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Which Posi do you have ?
    Eaton Gov-lock maybe. :confused:
