Changing gears How hard/technical ???
Discussion in 'The Garage' started by WinnipegK5, Sep 5, 2003.
  1. WinnipegK5
    WinnipegK5 Registered Member
    Aug 27, 2001
    66
    Winnipeg, MB, CANADA
    I just bought another 79 Blazer for parts especially the stock front and rear 4.10 posi diffs. My orginal plan was to swap front and rear axles complete which is heavy work but not technical. Would I be better off just changing the gears ?? I have 3.08's now.
    Mike
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You'll be much better off to just swap the axles. It's heavier work but will take less time to do it and you're less likely to mess anything up. </font>
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I agree /forums/images/graemlins/thumb.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Invite one or two mechanically inclined buddies over to help (and bring along some jackstands, unless your garage is awash in them), jack both rigs up fairly close to each other, and then swap out the complete axle assemblies. It'll take about half a day and you won't have to wonder if you screwed up setting up the gears. /forums/images/graemlins/cool.gif
  5. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Just FYI, BUY NEW U-BOLTS, do mess with trying to remove the olds and re-use them. I tried using mine over again, finally ended up taking a torch and cutting them off. Trust me the time you spend trying to remove the olds ones is worth the money for new ones. /forums/images/graemlins/thumb.gif The 14Bff tubes are larger diameter anyway so you will have to replace the rear if you are going 3/4 ton.
    Just my 2 cents
    Krennen
  6. WinnipegK5
    Aug 27, 2001
    66
    OK, the plan will be to swap the axles one at a time . I was a bit afraid of replacing the gears .
    Thanks for the advice!
    Mike
