changing gears in a front 10 bolt.. hard?
Discussion in 'The Garage' started by 58 apache, Jan 8, 2007.
  1. 58 apache
    58 apache 1/2 ton status
    Aug 26, 2006
    377
    clarksville,Va home of the body bag
    i have a chance to get a beefed up 10 bolt thats close enuff to pick up. it is geared 5.13 i need 4.56. how hard is this swap? i just tore down my 14bff to install locker.piece of cake. i know the set up is different on a 10 bolt so how difficult is it to change gears? do i need a different carrier? for now this 10 bolt is more feasable money wise for me than a 60. i wont be wheelin this rig real hard just play. i need the 8 lug pattern. i have considered doing a conversion on my current 10 bolt but it isnt 4.56 eather and i would have as much in my stock 10 bolt conversion as i would to buy this front that is built pretty stout http://coloradok5.com/forums/showthread.php?t=176200 crazy427 said 300. how much will it cost to change gears? oh and this is a stupid question but what is a 30 spline quick locker? thanks, eric
  2. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    It is very easy just time consuming you have to take pretty much the whole front end apart. But it can be done in a couple of hours.
  3. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    I had mine done (big mistake shouldve just found a d60 with 4.56) and originally it was supposed to cost $700-800 but then they said I needed new hubs and eventaully it came out to $1100
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Maybe two hours if you leave out some steps, like "checking pattern".:eek1:
    Checking pattern was talked about a while back. Turns out mustard works as good as anything you could buy "automotive".:haha:
  5. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    why so much? I`ve heard it only costs like 2-300???
  6. 58 apache
    Aug 26, 2006
    377
    well found a d60 instead so no need now
  7. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    I had to get anew carrier to go to 4.56. the gears were 145, the master kit was 85, axle seals were 20, carrier was 50, freight was 30, and labor was 560. And then the hubs were like $90 and then labor for that, and a new ujoint, and something else i think. Dont get me wrong it's a great shop and a bunch of people reccomended them but WAY too much for a 10b. If only id known itd be so much I'd have had a d60 up there right now
  8. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    It cost me about the same to have mine done. Biggest mistake I have ever made... :mad:
    They said it was an 8 hour job and I supplied all the gears and the install kit. They originally quoted me for $600 (labor/shop fees) But I had to get a new tie rod, and a bunch of little parts in the hubs too. so the grand total came to $1056 or something close to that.
    But on the upside, I know its done correctly and they warrentied their work too. Also they are the only shop I know of in the area that will setup a ring and pinion.
    You know what Ben, on second thought it might not be a good idea if I try to give you a hand, 2 noobs pissing on a front axel won't be good. :eek1:
  9. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    exactly what I was thinking
