changing gears in a govlock
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by outlaw612, Nov 24, 2001.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Can I change to 4.10's or 4.56's , I currently have a 3.73 geared govlock.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Is this a 10-bolt axle? If so, then yes, your existing carrier would work. The fact that it's a Gov-Lock doesn't really change this. The gear set up procedure is exactly the same.
    <font color=green>There's nothing like the smell of a rich V-8 in the morning...</font color=green>
  3. Blue85
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I should mention, though, that it might be cheaper and easier to swap the whole axle. 10-bolts were available in 4:10 Gov-Lock. You might also want to look into a 3/4-ton upgrade and just swap both axle assemblies. Remember that you're looking at over $200 per axle in parts and at least $200 again per axle for the setup labor, which makes a pair of 3/4-ton axles look pretty cheap, especially if the junkyard will give you a break for giving back your matched set of axles.
  4. outlaw612
    Feb 11, 2001
    2,342
    Sorry, I should have been more specific. Im doing this in a 14ff. I have 2 of them, 1 with 3.73 govloc and Im also looking for a 4.10 or 4.56 open or posi carrier because I dont have a carrier in the other 14.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The carrier break for a 14 bolt FF is between 4.10 and 4.56. So you can install 4.10's on the 3.73 carrier. You'll have to find a different carrier if you decide to go with the 4.56's.
  6. outlaw612
    Feb 11, 2001
    2,342
    Thanks Harry. I had someone tell me about Thick ring gears so the 4.56 would work, I cant remember who it was. Have you ever heard of this?
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Yea you can use either thick ring gears or spacers to make up for not having the right carrier. What the thick ring does is move the gear farther away for the carier and closer to the pinion becaue the pinion on higher numerical gears are alot smaller.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  8. outlaw612
    Feb 11, 2001
    2,342
    So I can just tell the gear company that I need the thick gears? Is there a specific supplier anyone can reccomend?
