changing np203 oil ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Apr 1, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    ok.. I put the part time kit in tonight... took pictures too...
    I noticed i have a leak from the bottom of the case on the back side.... I need to open her up and reseal it...
    Do i just remove the round plate and reseal it with rtv?
    or what?
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    there are some Roller Bearings in the center of that cover. so if you pull it be careful not to let them roll away... It may just be the bolts on the bottom, pull the out and put some RTV on the and put them back in. That's what I would try first If I where you
  3. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    If you are talking the rear plate for the front ouput shaft, then the berrings woun't fall out. The berring is that round thing in the middle of the plate that you can see from the outside. It is just pressed in, and is made in a way that holds the berrings. I would pull that rear plate and drain it that way. Then clean it up and douce it with rtv.
