Changing out outter axle shaft seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HispanicPanic, Oct 12, 2001.
  1. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    the reason im changing them is cuz my rear drum is full of grease and well i know i have the take my axles out and all that fun stuff, but my question is how hard is it to change out my outter bearings, since im already gonna get dirty. do i need special tools to install it i know what i need to take it out its the install im not to sure about thanx for any help
    <font color=purple>I put the Panic in Hispanic</font color=purple>[​IMG]
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A shop manual can really help here, and a slide hammer, and quite a bit of patience.
    Tim
  3. Grim-Reaper
    7,385
    Atlanta
    If the surface that the axle shaft rides on the bearings is in good shape then no need to change the bearings. If the bearings are bad it will eat the axle shaft.
    I don't need no damn shop manual, I got a pornographic memory.
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  4. HispanicPanic
    Mar 21, 2001
    351
    El Paso, Texas
    yea thats what i figured grim just thought i could get a 2nd opinion thanx guys
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    It would be nice to have a bearing installer that will push the bearings to the right depth, but you can just use the old hammer and socket routine. Make sure you seat it to the original depth.
    I have not found it necessary to replace any of my axle bearings though I have done several seals.
    Still Poundin' "pavment" after all these years!!! [​IMG]
