changing pinion seal
Discussion in 'The Garage' started by Jonny-K5, May 9, 2006.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    the pinion seal in my rear 10b is leaking.can i pull the yoke and replace it without screwing up the crush sleeve? what the proper procedure for doing this?
  2. dhilgenberg
    dhilgenberg Registered Member
    May 18, 2005
    11
    Antioch, IL
    take off the drive shaft unscrew the pinion hold the bearings in place and pry out the seal it comes out pretty easy well it should then put the new seal in andput the pinion and drive shaft back together remember your going to loose some fluid so make sure you get your 80 90 oil
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    The "correct" procedure is to change the crush sleeve.
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    There is more to it than this but I don't feel like describing how to do it for the 1000th time. If you do it this way I wouldn't expect your diff to last very long. Search and you will find your answer.
  5. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    guess i shoulda done a search first. found a post from 2 weeks ago. i think i'll try doing it the "correct" way.
