Changing rotors 87 4wd w/ automatic hubs.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by riggz, May 18, 2005.
  1. riggz
    riggz Registered Member
    Feb 9, 2005
    85
    Roswell, GA
    I'm trying to change the rotors out on my 87 K5 with front automatic hubs. Im quite baffled by this process. I've removed the caliper, the hub assembly, and the nut but the hub still doesnt want to come off. I still spins freely, but I cant see what else is holding it on. Any help is greatly appreciated.
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    It sounds like you have only the outer nut off, there should be a washer and an inner nut (similar to the outer). Poke around with a pick and you'll find the washer, pull it out and go after the inner nut. :thumb:
  3. Bigg R
    Bigg R Registered Member
    Feb 21, 2005
    34
    Martinsville,Indiana
    Automatic hubs should have a washer with 4 ears on it used to engage hubs, remove it with a pick or needle nose pliers then remove second nut! Rotor should come right off!!
