Changing seal/O-ring @ trans. linkage?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76jime, Jun 5, 2006.
  1. 76jime
    76jime Registered Member
    May 22, 2006
    5
    michigan
    Newbie here with a question. How do you change the seal/o-ring around the bolt that connects the linkage through the trans? Is it done from inside (removing the pan) or the outside. It's a 76/400 Jimmy with a TH350 trans.
    Part #?
    Thank you for your help.
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Unfortunately I don't think you can get it out from the outside without damaging something. IIRC the valve body must be removed to get the manual shaft out of the case.
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you can pop the seal out with a screw driver and then use a socket to seat the new seal it is not very hard at all and does not requrie tearing into the tranny
  4. dyeager535
    26,982
    191
    From the picture, that seal looks like it would be LOADS of fun to try to dig out with a screwdriver...
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if you can't get to it with a screw driver you can take just the shaft out and not have to remove the valve body, when the pan is off remove the clip that is on the shaft then remove the nut. the shaft will slide out and it will be eaiser to change the seal.
  6. 76jime
    May 22, 2006
    5
    michigan
    OK, I'm going to take the pan off and remove the shaft from the inside. More work, less risk. I'd hate to gouge up the trans. case removing/installing a $3. part.
    Thanks again for the help.
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    You can buy a tool specifically for removing that seal...makes it tons easier, especially if its in the truck. Maybe even try "borrowing" one from a trans shop - they are small enough, and can't be expensive.
  8. 76jime
    May 22, 2006
    5
    michigan
  9. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Thats the one, sorry I couldn't find a picture yesterday.
  10. 76jime
    May 22, 2006
    5
    michigan
    Great tool! 5 minutes seal changed..The End.
  11. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    The right tool makes some difficult jobs too easy.
