changing speedo gear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aj_tatted, Jan 12, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    how are you suppose to pop the speedo gear out on a 208?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    There should be 1 10mm retaining bolt, then the whole thing should just pull out of housing.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Follow the cable to where it goes into the T-case. It is on the passenger's side, near the rear. Remove one bolt and then twist the little round housing while pulling out on it. This helps to pull the O-ring seal free. The gear is right inside.
