changing speedo gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76chevy, Aug 16, 2000.
  1. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    How hard is it to change speedo gearson a TH 350? When you do it does transfercase fluid run out? I just bought a $58! adapter for the speedometer cable and transmission.I might as well change gears while I'm in there.
  2. 76chevy
    Aug 16, 2000
    246
    Utah
    I'll update this one. It is a piece of cake. I have a TH350/NP203 setup. Simple take off the speedometer nut and remove the adapter to the transmission. Remove the next nut. Transfer cas fluid will run out so have something to catch it. Next pull out the gear. Mine was a big metal one with 19 teeth and about 5-6" long. Put it back in the reverse order and add some 10-40 wt oil and you are done. Those with different transfercases may have a slightly different procedure such as gear oil instead.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Where is the cable that has the gear thatr you change? Where does it plug in on a 700R4? Thanks
    90K5
  4. 76chevy
    Aug 16, 2000
    246
    Utah
    I'm not sure on the 700. On my TH350 it is on the drivers side. Can someone else here help? Maybe the back end?
  5. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    On my 700r4 it is on the passenger side of the tail housing.
    John
    So Much to do, So LITTLE cash.
