Changing the ignition insert
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by yellowmoon, Jan 27, 2002.
  1. yellowmoon
    yellowmoon Registered Member
    Dec 30, 2001
    94
    Modesto Ca.
    I have a 72 blazer, and I bought a key set, so that all the doors, glove box, and ignition are the same. The only problem is I don't know how to change the ignition insert. There is a key hole and a small round hole next to it. Any help would be appriciated.
    Rob <a target="_blank" href=http://community.webshots.com/user/yellowmoon72>72 blazer 4 inch lift 35 tires</a>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=firstgen&amp;Number=281651&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>This should be what you are looking for</a>
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. yellowmoon
    Dec 30, 2001
    94
    Modesto Ca.
    Worked like a charm! thanks
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey Yellowmoon, does that re-key kit replace the whole key switch unit? Did you have to rewire the key switch or did you just replace the guts? I'm thinking I may have a falty key switch and just curios if the WHOLE key assy came with your kit?
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Burt,
    Most of the "re-key" kits just include the lock parts.....not the "rear" portion of the ignition switch....
    It won't be THAT easy for you..... [​IMG]
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  6. Burt4x4
    6,854
    Ya thats what I thought! Thanks Greg
