Changing tie rod ends?
Discussion in 'The Garage' started by tomy, May 20, 2005.
  1. tomy
    tomy Registered Member
    Jul 19, 2003
    34
    Orland Park, IL
    Is there a good write up anywhere on how to change tie rod ends? :confused:
  2. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    Uhhh, what are you stuck on?
  3. tomy
    Jul 19, 2003
    34
    Orland Park, IL
    I haven't started yet. I just want to get an idea of what's involved to see if i want to try it myself. Also is there a recommended brand of tie rod end to buy?
  4. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    I replace mine recently. Realy easy. Take of castle nuts. smack end with hammar till it pops out. Losen jam nuts and screw the end out. Might require a little sweetalking with a hammer to losen everything.
    Just a tip, measure center to center of the end before you disasemble the tie rod. Then when you put in the new joints put them to the same measurements as your old ones. Your toe in should be very close to what it was before if you do it right. I would still get it aligned afterwords though.
    As far as brands. Just use whatever you are willing to pay for. The man at napa told me that no matter how special they make them you aren't going to get any different preformance or life.
  5. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I disagree, a guy in my club snapped one in half, it was a cheap one from Auto Zone, I looked at it and laughed, I sold him a Moog tie rod end and it is much thicker and stronger. Probably the best OE Tie Rod end you can get. I'd say go with Moog.
  6. paveslave
    paveslave Registered Member
    Oct 11, 2003
    36
    Crestview, FL
    When I changed mine I popped the ends loose and measured the length from the center of one end to the center of the other end. Then I unscrewed the tie rod ends from the tie rods. I started the new ends a couple of threads (equal amount) then adjusted the tie rod to the same length as measured before center to center. I also had an alignment booked for the next day. There is a tool for removing tie rod ends (they have a tapered shaft and will usually come loose with a bang) or you can use an air hammer with a pickle fork (looks like a two pronged wedge).
    Pat :k5:
  7. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    If you are replacing the end then you don't need a pickle fork. If you ruin the treads it doesn't matter.
    Mudfrog, what in the world did the guy do? That had to be one big hit to break the end. I am suprised that the ball joint didn't go.
  8. paveslave
    Oct 11, 2003
    36
    Crestview, FL
    Air hammer.......more power......ugh
  9. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
  10. paveslave
    Oct 11, 2003
    36
    Crestview, FL
    It's just easier.
  11. paveslave
    Oct 11, 2003
    36
    Crestview, FL
    Work smarter not harder.
  12. tomy
    Jul 19, 2003
    34
    Orland Park, IL
    Thanks for the quick replies
    Thanks for the quick replies. Which parts store usually carry Moog parts?
  13. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    O'Reilly's, but be willing to shell some $$$$. I went to Napa and got their store brand for 1/2 price of Moogs, and just as good. Stay away from anything Autozone sells, it's all junk.
    John
  14. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    Auto zone has gotten very cheap latley. And the help is incompitent on top of that.
  15. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    It was in a mud pit, it was in a bind and I figured the ball joint would have broke first as well but the stucture was built so poorly it snapped in half.
  16. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    I guess you could look at it this way. At leased it was something cheap like a tie rod end insted of something expensive.
  17. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    I know this thread is old but...........advance auto sells Moog and they have free shipping over certain $$, ordered online and they shipped the same day.
    gonna install mine this weekend using methods described above, hopefully the alignment will be okay.
  18. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Setting alignment on a straight axle truck is really easy, search my username and "alignment" or "toe" and you should find some info.
  19. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Thank you very very much
  20. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    installed them and aligned it just like you said, was very easy, drives great and saved me some $$.....thanks again
